Hi Guys,
Just want to run something past you incase you've done something similar to this before.
what I have been asked to do is raise an area in between two roads with it tieing into the road level.
![itsnathanblake_0-1638459695920.png itsnathanblake_0-1638459695920.png](https://forums.autodesk.com/t5/image/serverpage/image-id/996379i975F859E3F29998F/image-size/medium?v=v2&px=400)
The red line above indicates where it will need to tie into the different roads.
What I was thinking of doing was drawing a regular polyine along the back of footway for the extent needed and then assign levels when in the feature line creation targeting the road surface.
i could then join these two feature lines and then just grade in between them at 0.0001 to create a flat level and then infill where needed. let me know if this is what you would do.
