This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Gabrielrafaelns
Gabrielrafaelns
Does anyone know how to resolve this error: "Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application."?
I have already done:
- I opened the truedwg software and converted it to autocad 2013;
- I used the EXPORTC3DDRAWING command;
- I saved as;
- I have already used the commands: audit and purger
- I have already opened the file on another notebook with a professional license (mine is a student one);
- I opened another file that had no problem at all, and now it is giving the same problem;
At,
Gabriel Souza
Engenheiro Civil | Liderança Técnica
• Civil 3D • Navisworks • Revit • Dynamo
LinkedIn
Accepted solutions (3)
matt_anderson_pe
It's not an error but rather a confirmation that the drawing was saved with an Autodesk application rather than a DWG knockoff.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
samir.rezk
Autodesk Support
Autodesk Support
Hi @Gabrielrafaelns
While this message is informational letting you know you are opening a legitimate DWG file, you can turn it off by setting the system variable DWGCHECK = 0
Hope this help,
Samir Rezk
Technical Support Specialist
Gabrielrafaelns
It's not really an error. My real problem is that when I export the layout to the model (right-click on the layout tab and export to model) my C3D closes. The only thing I noticed that was "different" was this warning.
But after doing a lot of research and talking to some friends, we realized that the problem was, for some reason, a dynamic block.
I exploded the block using the burst command and the problem was solved.
Anyway, I really appreciate your feedback!
At,
Gabriel Souza
LinkedIn
