Profile Text upside down
joeperkins_gai
joeperkins_gai
I couldn't find a solution to this. My profile labels (title, elevation, stations) are all plotting upside down. It just started happening. I am running Civil 3D 2025.
I regen to fix but it flips right back. I've set UCS to horizontal and everything,
brian.strandberg
Probably going to need to share your drawing to figure that out.  That is a bit weird, I can think of a couple of suspects but probably better if you can share the drawing.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
RobertEVs
Check your Edit Feature Settings for your Pipe Network
essam-salah
hi@joeperkins_gai
posing the dwg file probably help, no need to share the whole data just one profile view with the problem
joeperkins_gai
It was a UCS issue apparently.
essam-salah
so it works now?
