This DG do away with the copy/paste images?
RobertEVs
Advisor Advisor
Message 1 of 9
RobertEVs
It looks like my Copy/Paste command for clipped images is not working here this morning. Has Autodesk Civil 3D forum done away with that option?
I do not care for the attached image process.
Replies (8)
Message 2 of 9
RobertEVs
Test. I don't see my image pasted here can anyone else. If I try and paste, I get this message in this reply.
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Message 3 of 9
Todd_Rogers
I just tried and there is definitely something wrong.
Todd Rogers
Civil Administration
Message 4 of 9
Pointdump
Hi Robert,
What is "DG"? How are you trying to add an image to your post? Are you using the camera-looking thing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 5 of 9
Todd_Rogers
I assume DG is Discussion Group. He's referring to copy/paste. That's how I usually do it. It's not working for me either. The camera thingy does work, but he isn't wanting to do that.
Todd Rogers
Message 6 of 9
Cadguru42
The whole forums have this issue. Been that way for a few days and Autodesk claims to have put in a ticket. Remember, the forum redesign has been basically finished according to Autodesk and most of it was outsourced, so any fixes take a while.
C3D 2024-2026
Windows 11
32GB RAM
Message 7 of 9
RobertEVs
Hi Dave. Sorry about that DG is Discussion Group this one in particular. I tend to use acronyms a bit too much.
I used to simple run my snagit app, capture the screen shot I wanted, edit it if needed then CTRL>C and in here below my text do a CTRL>V. My image would get pasted with no need to save it out and attach it then insert it here.
I see it is still not working this morning
Message 8 of 9
RobertEVs
UPDATE:
So, what I have to do is save out my snagit image. Once saved I can then drag the file in under my message here, and it pastes like before. Just adds one extra steps. Question. When you view this message is there a profile clip image down here👇 or is it a 1.jpg attachment? On my end I see the image embedded in this message.
Message 9 of 9
Cadguru42
@RobertEVs wrote:
UPDATE:
It's embedded.
C3D 2024-2026
Windows 11
32GB RAM
