Text Symbol Won't Plot Correctly (Shows in Print Preview Though)
Nikki.Flack
Observer Observer
Nikki.Flack
Observer
Observer
I'm trying to plot text symbols (arrows) and it shows up fine the print preview, but when I actually plot it, the arrows show up as rectangles. Does anyone know what may be causing this?
Here's what I want it to look like (and what it looks like in the print preview):
Here's what it plots as:
ChrisRS
What Font are you using?
Christopher Stevens
Nikki.Flack
Observer
Observer
I'm using Arial font, size 0.15. I've tried changing the text style from RS125 to Annotative and several others and none of them make any difference.
ChrisRS
That does not look like Arial.
I cannot find those arrows in Arial.
Once we figure out the font issue, we will need to know what plot driver you are using.
It would be best if you posted a sample drawing.
Christopher Stevens
pendean
Community Legend
Community Legend
How did you insert the arrow symbols? That will tell you which font you used.
If you don't know...
Then find out how your plot-output driver is set to handle fonts to static images instead of "downloading", most likely all you need to do.
If you have absolutely no idea what anyone here is asking of you, then share your DWG file here please.
lim.wendy
Hi @Nikki.Flack,
Welcome to the forum and thanks for posting. Do share your drawing with us so that we can take a look and troubleshoot. It looks like you're using special characters from within the Wingdings fonts.
Meanwhile, look at the following resources:
https://resources.imaginit.com/how-tos/autocad-when-plotting-a-pdf-characters-are-plotted-as-dots
https://forums.autodesk.com/t5/autocad-forum/special-characters-text-to-pdf-plot-as-a-string-of-dots...
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
