We are connected to a WMS-service and are about to use their maps as a background for our drawings. The problem though is that the text on the map gets really small when printed out. In the paperspace view it all looks good, but after printing it the text is way too small (See attached pics). Is there a setting in AutoCAD Civil 3D to change the printed text size? Or is the problem on the WMS-service?
Best Regards,
Magnus
Hi Magnus,
Welcome to the Autodesk Forum.
When you style the label, are you using "Device" or "Map"?
Dave
Dave Stoll
Las Vegas, Nevada
Thanks Dave!
I havn't styled any labels. The labels are in the png-file (which I get from the WMS-connection), so I can not access them. However, the text did get bigger when I changed the DPI to a lower value in the plotter settings. The downside of doing this though is that the map is printed in a lower solution...
Best Regards
Magnus
