ive used MTEXTED and MTEXTFIXED and nothing has worked.
I want to be able to pick mtext in my dwg and make edits to it WITHOUT if rotating to horizontal when I'm editing. I want the text to stay rotated when I'm editing it.
If setting MTEXTFIXED to 0 or 1 didn't work. It may be a graphics card issue. Are your drivers up to date?
There is a slight difference if you have MTEXTED set to OldEditor.
If MTEXTED is set to “OldEditor,” multiline text is displayed in the Multiline Text Editor, and the setting of MTEXTFIXED has the following results:
0 |
Displays the Multiline Text Editor and the text within it at the size and position of the multiline text object in the drawing. Text too large or too small to be edited is displayed at a minimum or maximum size. Text that is rotated is displayed horizontally. |
1 or 2 |
Displays the Multiline Text Editor at a fixed position and size based on last use, and displays text in the editor at a fixed height. Text that is rotated is |
Allen Jessup
CAD Manager - Designer
He could tell by just looking at it?
Allen Jessup
I, truly, can't either. But it's usually the first thing to try.
What version of Civil are you using? Are all the available updates installed? What graphics card are you using? Is it Certified?
Allen Jessup
