Does anyone know how to orient the text in a linetype perpendicular to the radial line of the arc when the radius is minimal? Below is a snip of the .lin file and the linetype. Notice the (QLB) strays from the arc. The text is justified middle center and I have tried both u= and r=. I don't need the text itself to arc (as in arc text) or anything, I just need it to be oriented perpendicular to the radial line, or at least close (look better).
Try this. It has a larger negative movement before the text and then places the text at a x= position. Somewhat simulates the text being center justified in its placement. ...note, its not perfect.
*CABLE TV QB,Buried Cable TV ----BTV----(QLB)----
A,.20,-.07,["BTV",Simplex,y=-.03,x=-.05,s=.06,u=0],-.12,.20,-.12,["(QLB)",Simplex,y=-.03,x=-.1,s=.06,u=0],-.15,.25
Thanks so much for the response. That works for the small radius. Unfortunately, that also creates other issues when the radius is larger. I thought maybe there was something I was missing in the string of data. I'll keep tinkering with it. I have one that is close. Again, thanks!
Place each character in the linetype as it's own entry. It becomes a very long definition but should do what you want.
One entry for B, another for T, one for V, then your dash then the (, Q, L, B, ).
IME it's best to set a company standard to keep linetypes to less than a few characters.
John
John Mayo
Yesterday I revisited individual characters and found what was wrong. They look great now! Then I saw these two comments and you both are correct. It's r=0 with individual characters. Thanks guys for all your help!
