Civil 3D Forum
Text Lineweight Issues
2 REPLIES 2
nusouthsc
207 Views, 2 Replies
  Hi all,
I have a issue with my text lineweight. When I am working in a drawing, all of a sudden when I create new text the lineweight automatically goes to 0.13mm. No matter what layer I am using. How does it get switched from "Bylayer" to 0.13mm. It has happened randomly in 3 or 4 drawings.
Thanks in advance.
Josh Ellis
Nu-South Surveying
Anderson, SC
Josh Ellis
Nu-South Surveying
2 REPLIES 2
tcorey
in reply to: nusouthsc
If you type LWEIGHT before running the text is it set to Bylayer?
Do you know what command(s) you have run immediately before the setting gets changed?
You didn't mention your version, but 2017 has the System Variable Monitor (SYSVARMONITOR command), where you could set the value (set CELWEIGHT to -1 (include the minus sign)) and then get a warning if it gets changed.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
nusouthsc
in reply to: tcorey
  Tim,
I have tried to pay attention to what commands trigger it with no avail. But, the lweight command fixed the issue. Not sure how it gets changed.
That was simple. Thanks for the help!
Josh Ellis
Nu-South Surveying
Anderson, SC
Josh Ellis
Nu-South Surveying
Rail Community
