text in command bar not showing
dilsmails
Message 1 of 27
dilsmails
text in command bar not showing the text in the command bar at bottom of screen does not show, however, I am still able to type in the command but only shows in the " | " and when i press the tab its moving but text is not displaying, f12 also the same
Dileep
Replies (26)
Message 2 of 27
Pointdump
Dileep,
Please post a Screen Shot.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 27
rkmcswain
Is your text color setting the same color as the command line background?
Message 4 of 27
Jay_B
Is it possible your command window has been reduced to 1 row of text Like this screen shot?
If so, try dragging the separator at top of command line window upward increasing the number of rows displayed.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 5 of 27
dilsmails
Not resolved
Dileep
Message 6 of 27
dilsmails
Image-1
problem starts
image-2
After pressing space bar
image-3
After pressing tab or space bar 2 or 3  times (f12 is not working all of this case)
image-4
after draging the command bar
Dileep
Message 7 of 27
dilsmails
image-5
Dileep
Message 8 of 27
Pointdump
Dileep,
Here's something to check:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Command...
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 27
Jay_B
Dileep,
Did you try  R.K.'s suggestion of verifying the Text color isn't the same as the background color?
Check the "Active Prompt Text" color setting in Dave's screen shot.
Drawing Window Colors dialog can be found here:
Options > Display Tab > Colors > Context: Command Line > Interface Element > Active Prompt Text.
C3D 2018.1
C3D 2016 SP4
Message 10 of 27
wfberry
Did you try changing the drawing file tab at the top of the drawing, then back again?
Bill
Message 11 of 27
dilsmails
Sir i checked that settings, but no problem with that.the problem is i cant type any thing in my camand bar please see my screen shot image -5 thanks
Dileep
Message 12 of 27
dilsmails
Dileep
Message 13 of 27
Pointdump
Dileep,
Do commands in the ribbon still work OK? Does Dynamic Input work?
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 27
jim.poole
Bill
Good call Bill...
I had 2 drawings open, the commandline on the drawing I had selected didn't appear to be working - I found this thread; switched to the other drawing, and hey-presto - there were lines and lines of text... 🙂
Seems the first drawing had remained active, even though the second drawing was displaying.
JP
Message 15 of 27
RBassadone
I'm having the same issue; I've tried all of the above, restarted autocad, restarted windows, opened/closed application/file, hid the command line, regen command, dynamic input on/off.... nothing.  What on earth is going on?
I've had this before, read this thread and I think the switching between documents did the job.  But not this time; now I only have one document open.
Message 16 of 27
Try    CTRL + 9
Message 17 of 27
wfberry
Here is a shot in the dark.
Using the "F2" key it issues a detached command line.  Perhaps that might help using this command line.
Bill
Message 18 of 27
j_schroeder1
I'm having the same issue. Switching to a different drawing tab and back fixes the issue... temporarily, then the problem returns. Sometimes it will revert back within just a couple command prompts. I haven't been able to identify any patterns present prior to this issue arising. I have noticed that when I switch to a different drawing tab, the text that failed to appear in the "problem" drawing shows in the command line of the new drawing I tab over to.
Message 19 of 27
j_schroeder1
Follow up: This forum has what I believe to be the correct explanation. Post 8 of 24 provides the explanation. Post 11 offers a solution.
https://forums.autodesk.com/t5/autocad-civil-3d-forum/command-line-stops-responding-2015/td-p/514083...
Message 20 of 27
j_schroeder1
Just a final follow up on this topic. I used LEVELOFDETAILOFF as recommended in the other forum. It's been about two weeks since I made the toggle, and have not experienced the autosave sending me to a background drawing since. Have not noticed any other performance differences from making the switch either.
