Hi, I have a new issue that now whenever opening a new drawing, my QNEW path setting doesn't work and I get a standard metric drawing opening without any of my template settings and also when opening any other template from my templates folder, all the drawing open the same way, i.e standard metric
Have tried changing the file path but seems something is overriding all new drawings.
Solved by SSDM. Go to Solution.
Did this ever work or is this a new installation?
Wondering if there is a maximum # of characters in the file path that has been exceeded.
Check your drawing template file location setting.
Blair,
Shot in the dark--Try taking the spaces out of your DWT file name.
Dave
Dave Stoll
Las Vegas, Nevada
Blair,
Dave
Dave Stoll
Las Vegas, Nevada
Template folder is correct also. Can locate all templates from start menu, including 'out of the box' templates plus my custom templates, but they all open the same way as a standard drawing with no pre- built layers or styles
Think I might be finding out why, seems all my templates are in a more recent version than my C3D 2021! even though I created my own ones. Have attached my dwt here, please let me know if you can open it, if so kindly send back as 2013 or something? Have also attached teh error message I recive when trying to open the file directly from my drive and not through C3D. No idea why they would have changed, even the 'out of the box' templates are the same.
Blair,
I can't open your DWT. I get same "could not be opened" message. RECOVER gives "Unable to recover drawing file" message. Corrupt drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Blair,
Dave
Dave Stoll
Las Vegas, Nevada
I was able to open the posted DWT with Civil 3D 2020.1.2 with no issues. So, 2021 should be able to open it as well.
@SSDM wrote:
<<............templates used to be on the company server.........>>
As an experiment, try this:
If you are successful in opening the correct template then the issue is accessibility to the CLOUD, the location where your template is now stored and indicates the QNEW button cannot access the CLOUD.
Chicagolooper
Chicagolooper
I tried using DWG TrueView on it and I get the same message, that the drawing was created with a newer version. How can that be? Are you on a Beta program of some sort and used Beta software to create the template?
Hi all, update to this and thanks for the help and suggestions.
Have worked out the issue and may want to kep this in mind if your company goes through the same procress.
While migrating our company away from site based servers to the clould, all of our .dwt files were corrupted. I was able to local our orignal files on our local server and recopied them across and the problem is now solved.
