Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Template Report volume comes all volumes equal to zero. see the screen shot...
e_omairquliey
Message 1 of 11
e_omairquliey
When I get volume of template from section menu from add table and select Material volume, the table comes true but as AutoCAD object and correctly but when try to get them from report volume, they come all equal to zero .... I don't know why??
Replies (10)
Message 2 of 11
ecfernandez
Hi @e_omairquliey, if you are using C3D 2023, you might have been experiencing a problem we already solved here in the forums.
Check the information in the following link, and please let us know if that solved the issue:
Link: Volume report
Best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
Message 3 of 11
BrianHailey
It looks like you're using the volume report under the corridor option in the Toolbox (please correct me if I'm wrong). It seems to be working just fine for me on the dataset I tested it with. Could you try running it on the attached drawing and see if you still get zeros?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 11
e_omairquliey
It didn't work I can't get the volume report of your template in the file you sent to me.
Message 5 of 11
e_omairquliey
I have 2024 version, I will try to do the volume report by lim.wendy and note you with results.
Message 6 of 11
e_omairquliey
Hi @ecfernandez , I tried replace the files of xsl folder with lim_Wendy's xsl files but I still the tables come out with zero.
Message 7 of 11
ecfernandez
Hi Guys!
Hi @e_omairquliey, as I pointed out in my post, that solution is for C3D 2023. Unfortunately, that has not happened to me with the 2024 version. It should be interesting to see your file and figure out what is happening with it. Can you share it?
Regards!
Camilo Fernández
LinkedIn
Message 8 of 11
BrianHailey
Just opening that drawing and running the report didn't work for you? I didn't have to do anything special to do it.
Check to see if you have this on your system: "C:\ProgramData\Autodesk\C3D 2024\enu\Data\Reports\net\C3DReport.dll"
If that is missing, try a repair install? Or uninstall then reinstall? Or something else? I don't think resetting your user settings will resolve this as that file isn't in the user location, but you could try that before doing the uninstall then reinstall. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Resolving-user-spe...
GEI Consultants
My Civil 3D Blog
Message 9 of 11
e_omairquliey
Okay .I will send the dwg file to you to see if you can get it out from your 2023 version.
Message 10 of 11
BrianHailey
This is what I'm getting in 2024.3:
GEI Consultants
My Civil 3D Blog
Message 11 of 11
e_omairquliey
There are two Materials Asphalt and basecourse.
the normal earthwork table cut and fill comes correctly and the wrong table when you select the template volumes which they are Asphalt and basecourse.
