hello, i have a problem if someone could help me please , i was trying to add a new column with a certain formula i make myself on the table is it possible ?? , and if not is it possible to let the program add the exact area of the volume calculated in the table not only the Plan area as shown in the photo attached , thanks in advance.
Solved by ChrisRS. Go to Solution.
I am no sure if this is possible, i myself would add a Mtext object with a mask over the pink value.
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
Amplify your skills to a new level!At this time formulas don't work in C3D tables.
Rick Jackson
Survey CAD Technician VI
@rl_jackson @Zlatislav.atanasov ok thanks, is there a way to know the volume of each color area VOL exactly as the volume written in the table doesn't represent the shown color area only.
Christopher Stevens
Christopher Stevens
You cannot do this automatically in a table.
You can accurately calculate the donut volume, using the Volumes Dashboard and Bounded Volums.
Notes:
I have not investigated Project Explorer (PE) with regard to this issue.
PE is very powerful. It appears that it is actively being developed/improved. It is bright and shiny.
I think that PE effectively ends Autodesk/Civil 3D development of standard/existing Civil 3D tables and reports.
Christopher Stevens
Hello, @ChrisRS I appreciate your help, actually, that's the exact method I am using right now, the problem is that it's not easy when it comes to big scale projects, I was just confused why does the table shows an area that is different than the corresponding volume, I didn't know about PE before, ill investigate it and report back if I found a solution , thanks !
Good luck with PE.
I think you have a workable method, @nezarismael7. Hopefully my instructions will be useful to someone else.
Looking at your original post, I do not understand what is incorrect. It is not obvious to me. Incorrect tables are indeed a problem.
Christopher Stevens
the original post was about the same matter, I was trying to know how the area and volume in the table are calculated ( explained in the photo attached below ), thanks for all your instructions.
Are you talking about Are or Volume discrepancies?
Without your drawing, I really can't troubleshoot.
The Area is the area of the various donuts.
The Volume is the area of the various cookies.
The pink and I checked the pink and blue areas. the look OK to me.
Volume by average end area:
full bottom of violet area = 215+279+369 = 863
full top of violet area = 279+369 = 648
violet volume = (863+648)/2 x 0.25 = 189 (190 in table) CHECK
full bottom of pink area = 279+369 = 648
full top of pink area = 369
pink volume = (648*369)/2 x 0.25 = 127 (128 in table) CHECK
I'm still not seeing a problem.
Christopher Stevens
yes, I am with you in all of the above, but let us take the pink color, for example, we said before that there is no way in the table to calculate the ( pink donut color) Volume, although the table gives the area of the same part, so if you want to divide the volume by the corresponding area it won't give you the right average depth of the area.
my problem isn't the results coming from the table which I know is right from your explanation, my problem is there is no method to check the table whether the numbers in it are right or wrong outside the program .
I am with you regarding no simple way to check outside of the program.
The best that I can do:
Pink donut range is 1.0 m to 1.25 m.
Average Depth = 1.125 m
Pink area = 278.73 sq. m.
Pink volume = 278.73 x 1.125 = 324 cu. m.
How does this compare to your donut volume calculated with bounded volumes?
You could use information in this table to manually create an AutoCAD table or Excel table with cumulative area, average donut depth and donut volume.
I am curious. why do you need the donut volume?
Christopher Stevens
Well I use it on several occasions, for example when I try to calculate a new earthwork ( cut & fill ) quantities done by dozers and quantities done by excavators & dumper trucks, it helps me in either making transportation plans inside the site or in the project estimation phase to know the amount of dozing in the project.
