System Variable Change appears and Civil 3D Freezes. I reset it the SYSVARMONITOR to default but when I run a command it changes again and freezes. Any suggestion on how to fix this issue?
If you hit ESC does it clear the freeze up? If that is the case it sounds like it is loading off-screen.
Press ALT + SPACE then M, then use the arrow keys to move the window around until you can see it.
