Civil 3D Forum
Synchronize all surfaces
5 REPLIES 5
3157 Views, 5 Replies
is there a command or a lisp that allows me to synchronize all surfaces at once?
M_Grey
5 REPLIES 5
david.zavislan
Synchronize References command in the Data Shortcuts panel of the Manage ribbon tab.  This will synchronize all references.
David Zavislan, P.E. | Wood Rodgers, Inc.
Thanks David! Smiley Happy
jim.poole
in reply to: david.zavislan
I was wondering if there was a command where you can select only the surfaces you want to synchronise - i.e. just the ones with the warning symbols.
e.g. I have a drawing with about 20 shortcuts to it, I modified a drawing (which contains about 7 of those shortcut sources) and resaved.
My master drawing now has warning against the 7 shortcuts which have been resaved (even though I only modified 3 of the 7 surfaces...?).
I only want to synchronise, the 7 (in fact the 3 really) but not sure I can do that as one command, it would have been quicker to do them one at a time, as CAD is now synchronising all 20... yawn... time to put the kettle on...
doni49
in reply to: jim.poole
As of right now it's one-at-a-time OR All-data-references-at-once.
But here's a relevant idea that would be worthy of a vote from you (it would solve this specific issue).
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/datashortcuts-to-update-only-the-objects-that-a...
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
jerry.balch
in reply to: doni49
We are going to be using sheet set manager to publish a lot of PDF's is there a way to force ACAD to sync these references on opening a file? When we publish now for some reasone we get no contour lines showing up until we synchronize them.
Rail Community
