Right, the grips don't work and I don't know how to make them work. Is the
"Change swath width for group" not working?
Matt Kolberg
Global CADD Systems - A division of Cansel
"dickmackey" wrote in message news:6339416@discussion.autodesk.com...
> Mr. Kolberg
> When I created the sample lines I gave them a swath width of 175' left and
> 0' right. It seems that I can edit the left side using grips one at a
> time, sample line properties one at a time, I can even edit them all at
> the same time, using group properties. Apparently because I used a 0 swath
> width for the right side I have none of these options available.
> Next time I will use a small swath width that way I will be able to edit
> in the future. Although I would like to know if there is a fix to this now
> because the drawing i am working with has multiple surfaces, sample line
> groups, materials, and Section Views laid over each other. There is no
> easy way to just create new sample lines.
> The file Is to large to attach.
