Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
Survey points and blocks/symbols Civil3d 2019
3 REPLIES 3
489 Views, 3 Replies
I'm trying to figure out if you can have your blocks (manholes, wells, lights, etc..) separated from the points in Civil3d? I do remember in LDD they were separate so that you could freeze the points and only show the symbols associated with the Survey points. I already have blocks associated with the points using Point & Label styles and Desc Key sets.
Chris
3 REPLIES 3
tcorey
Apply a point style that has the point label style turned off (see the Display tab).
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
Thank you Tim
_Hathaway
That is the way we have ours setup as well.  The point #, code and elevation are on a text layer which can be frozen independent of the symbol.   That is how we control visibility, not the very non intuitive point group hierarchy sorting Autodesk pushes.
Rail Community
Ā
Ā
