Announcements
Survey Point Trouble (Moving and Rotating)
I am having trouble with moving my survey points. I was able to move and rotate my points earlier but now I am unable to move or rotate them. Please help.
Replies (10)
user181
Hi @Anonymous    Maybe the points are locked. Click on points in prospector and look for the red icon next to the point number. You can also select a point and look on the properties palette information section to see if its locked.
It doesn't show that it is locked. When I use the Move command I click on the point I want to move and when I attempt to move it it look like it flickers when I move the mouse around but when I click where I want it to be placed it does not move.
user181
Can you post the drawing or part of it so someone can take a look?
wfberry
In the same drawing?  If these points are entered with a survey database, perhaps not.
Normal points can be moved if "Allow checked-in points to be Modified" is set to TRUE in:
Prospector --> Settings --> Edit feature Settings - Point
Bill
Which Tab is that under? I might be looking over it but I can't find it.
Ok
TerryDotson
The problem is that they are flagged as SurveyPoint = True.  The answer I'm waiting on also.  What does a person do when they receive a drawing (only) and don't have a Survey Database.
I honestly have no idea. I'm new to AutoCAD. I've only taken a basic AutoCAD class in college.
TerryDotson
Good luck on the new thread, I really hope someone chimes in with an answer.  I've spent an hour or so searching and can't find one.  The only workaround I can suggest is to export the points, erase them and import the file.
rl_jackson
When you have a drawing that has survey points from a database, simply create a survey database and import the points from the drawing. Once there tied together you'll be able to translate and move just as before.
Rick Jackson
Survey CAD Technician VI
