Survey Data Collection Link
thendryx
thendryx
We recently tried to convert a RAW data file to FBK and the program aborted after running several setups.  I have viewed the raw data on the data collector, but there appears to be no error.  What other methods of conversion could I use to convert the RAW data file to a TXT file?  I was hoping that our local AutoCad/Topcon dealer would be able to have a work-around, but they seemed stumped too.  We have never encountered a problem usitlizing the Survey data Collection Link with any of our traverses prior to this time.
Thanks in advanced for any help,
TLH
Todd_Rogers
Try Stringer Connect.  It's free and easy to use.  If you can't find it, post back here and I will get it to you.
Todd Rogers
Civil Administration
thendryx
Wow, thanks for the quick come-back.  However, when I accessed the site and tried to download I recieved as message "... StringerConnect.exe is not a valid Win32 application."  So I guess I'll have to check with our IT dept.
TLH
Todd_Rogers
Right click on the file that is attached here, StringerConnect200811Install.png and select Save Target as...
Once downloaded, rename it from a .png to a .exe.
Todd Rogers
