Civil 3D Forum
Survey data base duplicating points on re import.
2 REPLIES 2
richardKTHG4
287 Views, 2 Replies
Hi All,
I have received a updated survey data base file due to some more points being needed. I have followed the Autocad help of going to the Survey tab / Survey data base / re-import. In imports all the points again not just the new ones so I have multiple points on top of each other with the same data.
Any ideas how I can stop this please?
Regards
Rich
2 REPLIES 2
in reply to: richardKTHG4
Try removing all the points and add them again. In the future add the points as seperate files, making sure you renumber the points in the second group so they do not override the first group.8
rl_jackson
If your importing the points to an existing SDB, and don't want all the points just open the CSV or TXT file and delete all the ones that already exist in the SDB, import as a seperate import event as @Anonymous said.
Rick Jackson
Survey CAD Technician VI
Rail Community
