Hi all. I haven't work on C3D in 2 years. I have two surfaces. One a pond and the other a river flowing out. I can't seem to join the two and open the gap on the pond outlet. Any suggestions?
Hi
I cannot undestand very well what you want to do?
Find the minor distance between surface...?
Please send a jpg o directly the dwg file
Welcome back to C3d
ok, you need to join two surfaces.
I would create a new surface, that will contain both surfaces.
that way if you have to change one of the original surface the combined will update.
ok,
Surface
Create New Surface (ope dialogue and give a name)
go to Toolspace
expand the New Surface
scroll down and find and select Edits
Merge surface
pick one surface and OK
now you have added one of the surfaces to New Surface
and repeat the Merge surface for the second surface
and now you have both added as one surface
select the New Surface and turn on the tin lines
select Surface from the top of screen menus
Edit surface and flip or add lines as needed to fill in any holes or problem areas.
You can delete points from the surface and make the outfall hole as needed.
good luck,
nonbeard13
Hi all
Thank you for the responses. I actually got it sorted and the surfaces work perfect
The client came back and ask to put in the original NGL, the one that was worked
on was back filled. How do i move all the alignments and corridors from the
existing surface to the new surface without redoing the whole design.
Also i need to put in a step in the embankment and move the service roads 900mm
out. the drawing is too big to to mail.
@Anonymous wrote:
Welcome back to C3d
ok,
Surface
go to Toolspace
Merge surface
good luck,
nonbeard13
