What I typically do for this is create a volume surface with the existing ground as the base surface and proposed ground as the comparison surface. The theory behind this is that the base surface is the datum for the volume surface, whereas the datum for a normal surface is elevation 0. So anything above the base will have positive elevation and anything below will have negative. A spot elevation label on the volume surface will effectively show the difference between the two surfaces.
Zachri Jensen, PE |
