- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
- I found that boundaries cannot be added to DS surface reference objects but that a single polyline mask can be; however, the polyline is a static object with regard to my road design and I would like to have my road design dynamically mask or hide the existing grade surface.
I tried to add the road surface as a boundary to my existing grade surface and found that since the existing grade surface is the target surface of my road surface it cannot have boundaries made from my road surface. The alert box also suggested that I make a copy of the surface to add the boundaries to.
I am trying to add my road surface as a boundary to the copy of my existing grade surface but only get "Error adding boundary" when I try it.
- The road surface is dynamically linked to my corridor.
What am I doing wrong? How should this be done?
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
