If I have a Proposed Surface and it is labelled with spot and slope surface labels in a drawing called Grading.dwg.
And I data shortcut that surface into a drawing called Sections.dwg.
And I want to show a portion of the plan view of Grading.dwg in my Sections dwg but I don't want to X-ref it into the Sections.dwg because the Proposed Surface from the Grading Plan is Data Shortcut into the Sections.dwg and I don't want to create a circle reference.
Is there a way to bring over just the surface labels from the Proposed Surface in the Grading.dwg into the Data Shortcut Surface in the Sections.dwg, without having to re-label everything individually on the Data Shortcut Surface in the Sections.dwg plan?
I guess I am looking for the Auto-draft button. ![]()
Michael,
Civil Design Technologist (Exploration Technologist)
Civil 3D 2013
Windows 8
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
32. GB
64-bit Oepration System, x64-based processor
No Pen or Touch Input
