Surface in Object Viewer
Hi There,
I use Civil 3D 2019.
When I view any surface in the Object Viewer mode, it initially looks good. However, as soon as I start rotating the surface, some of the areas on the surface smudge and I can't really see the definition of the surface. It doesn't have anything to do with the grade of the contours, because it happens with a flattish surface as well as a surface with heavy grades.
Looking forward to receiving some assistance as to how I can get rid of the smudging.
(I attached a snapshot)
Regards
Christopher
Pointdump
Christopher,
I can't see the smudging in your screen shot. Can you add an arrow to the problem area, or better yet, post a particularly problematic drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Hi Dave,
All of the green parts are the smudging. There should no be any green solid hatching.
I did get to figure it out. I had to edit the surface and switch the boundary off under the plan and the model settings.
Thanks.
Christopher
