I have created a ditch/trench corridor and applied a surface to it. It looks fine in the beginning, but then it goes outside the ditch and connects to the bottom of the corridor. The subassembly contains only a ditch.
I would like to know, why it behaves so and what the solution is, to make it follow the corridor alignment only.
Attached is a pic of the corridor surface and of the assembly.
Thanx
Solved by mathewkol. Go to Solution.
That's the correct boundary type. If any part of your corridor crosses itself, such as a tight insser radius, your boundary may have problems. Can you attach the DWG?
I'm glad to have helped you out. I guess now you just need to figure out how to fix the corridor. Or, you could maybe use the Interactive boundary tool to create the boundary.
