Hi there
Surface contour labels show multiple text entities (Label Text wording). How do you make it show only elevation? Thanks
Bazza
Solved by ChrisRS. Go to Solution.
Solved by rl_jackson. Go to Solution.
Looks to me like you've added multiple text components without the elevation component. You'll need to edit your label style to be an elevation so that is what is displayed.
If you post a file, I'm sure someone can get you in the right direction.
Rick Jackson
Survey CAD Technician VI
@rl_jackson is correct, the text style for the selected labels (Standard?) appears to have 2 text components.
The correct component is probably:
General Name: Surface Elevation
Text Contents: <[Surface Elevation(Uft|P2|RN|AP|Sn|OF)]>
Border Background Mask: True
Delete the extraneous text component. Probably:
General Name: Text.1
Text Contents: Label Text
Border Background Mask: false
Christopher Stevens
