Civil 3D Forum
Surface Appearing different Colours
2 REPLIES 2
itsnathanblake
356 Views, 2 Replies
Hu guys,
I am currently creating a large amount of surfaces on site and I am just curious to know if the surface is appearing a different colour is that signalling there's an error?
thanks
2 REPLIES 2
user181
in reply to: itsnathanblake
It looks like maybe your visual style has been changed from 2D Wireframe to something else.  With nothing selected look at the properties palette and at the bottom check the visual style and change to 2D Wireframe if it's something else. You can also change it with the controls in the upper left of the drawing window.
I looks like your surface is using a surface style that shows slopes.
Select the surface, right click and choose surface properties.
You can either change the surface style in use or edit it to turn off the display of surface slopes.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Rail Community
