Civil 3D Forum
Surface and Boundaries
8 REPLIES 8
Message 1 of 9
1283 Views, 8 Replies
Good Day Sir/Ma'am,
I am new in Civil 3D and I have a problem dealing with surfaces and boundaries as I cannot get the actual boundaries in the individual areas for my cross sections particularly with area cut and fill with sections having retaining walls and others. I attached screenshots showing the shape of the area fill, the boundary is in corridor shrinkwrap so I think it's the effect having the boundary extends over to the end of retaining wall hill. So I tried not to shrinkwrap and do it individually through add automatically daylight, retaining wall front, etc. but the boundaries for cut was affected and did not area it correctly. I hope you can give me solutions. thank you in advance and more power.
boundary on corridor shrinkwrapboundary on corridor shrinkwrapboundary on corridor shrinkwrapboundary on corridor shrinkwrapboundary on individually add  automatically daylight,RW frontboundary on individually add automatically daylight,RW front
8 REPLIES 8
Message 2 of 9
Neil.Aryan
Draw manually and add that to surface boundary, but make sure that surface shown on section and boundary adding both are same.
If not fixed, feel free to share file can have look and find the resolution.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Project Manager | Civil | ACE Inc.
Certified Civil 3d Professional | YouTube | My-Blog
Message 3 of 9
Hi!
Can you attach drawing?
Without sharing its very difficult to solve this issue.
Message 4 of 9
in reply to: Neil.Aryan
Thanks you very much for noticing my message and sorry for the late reply. i attached the file for reference sir. I'll wait for your kind help.regards
Message 5 of 9
I tried to attach the file sir but dunno if it was sent to you?
Message 6 of 9
Message 7 of 9
Jowennl
Hi @Anonymous ,
Try the following concept if it will work for you. See attached Concept-ToGetVolumeBdry.dwg as a guide.
A. Insert String or Mark point to each location where you want to have Volume boundary. (Do to all SA affected)
B. Update Code Set Style to show new point code like color Red / Pink / Purple or any that will stand out.
C. Re-Build Corridor
D. Remove current outer extent boundary.
E. Add bdry using Point Code e.g. VOLBDRY
F. If you want the surface to transition abruptly then add 1mm in each start so it will look like 90 deg bend or transition.
G. Do your volume again and see how it goes.
Guide 1Guide 1Guide 2Guide 2Guide 3Guide 3
Cheers,
Jowenn
Message 8 of 9
in reply to: Jowennl
Good Day Jowennl. Thank you very much for your kind and fast help. i'll gonna try your recommendation. GOD BLESS.
Message 9 of 9
Sir how can I add the area of cut below the curb and gutter? I attached a jpeg file
Rail Community
