Support on workflows Ore body/ block/reserves geological modelling in Civil 3D
geosolution
Observer
Observer
geosolution
Observer
Observer
Hey Friends has anyone tried ore body modelling in civil 3d?
I have a set of drilled boreholes data and want to do Ore block modeling in Civil 3D, I'm looking for a workflow to carry out Mineral Resource Estimation, and Mine planning in civil 3d? I have tried using the geotechnical module to visualize the drilled boreholes/bores but couldn't edit the lithology boundary.
Is there a workflow to accomplish:
1.      Orebody modeling in Civil 3D
2.      How to find out the volume of overburden and reserves within the given block area using borehole/ bores data through civil 3d and make geological profile sections.
3.       How to constrain the estimation of ore and waste volume within boundary limits, which again be altered, how can that be done?
3.       Is it possible to plan variable sizes of benches within the block area which will help us later to calculate the mineable portion of the ore, overburden, or waste generated?
please share your advice.....
rl_jackson
Have you looked at the Geotechnical Module?
Rick Jackson
Survey CAD Technician VI
geosolution
Observer
Observer
Yes Mr. Rick I did try Geotechnical Module, but I couldn't edit the lithology boundaries in it! is there a way/workflow to do ore body modeling in civil 3D?
neilyj666
Civil 3D isn't really the tool for this and I'd suggest you'be be better off with dedicated mine planning software e.g. Vulcan (but $£$£$££$£$£$).
You may be able to use the solid modelling tools in vanilla CAD but IMHO you will endure hours of frustration (sluggish performance/crashes etc) attempting this in Civil 3D
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
