Super elevated planar sidewalk with intersection
PeterKozub
PeterKozub
Hi
I am designing a sidewalk which is super elevated
with a normal lane width of 0.718 meter.
So thus the overall width is 1.436=2*0.718 m or imperial 56.5 inches.
In the calculate super for the sidewalk alignment i set the normal lane width
to 0.718m and normal lane slop at 0.00% and a walking speed of
50 Kmh or 31 mph to populate the super elevation table for this
class 1 sidewalk.
Note: Low side Pivot is on inside curve of sidewalk.
So i am having a difficult time getting the low side sidewalk to be
at elevation 99.00 O/S 0.718 from CL.
Under the sidewalk are standard specification hardwood timbers to support heavy groups of
random zealot protesting marchers  who are against against any kind of industry
that generates jobs. These large groups of zealots are every where here in Canada
and seem to emerge in protesting mode always after listening to CBC radio combined with
to much heavy caffeine tea.
Note at end of support timbers is the elevation 99.0 inside curve.
So those with planar road experience please comment on this website
and your responses will be treated with strictest confidence and ridicule
To aid in your scientific C3D cad analyses this super elevated sidewalk is sometimes called a "railway"
do not let the term "railway" make this sidewalk seem complicated its not.
Pete
25 PKS Cant R3 Rail VS Cant-Model Planar.jpgLevel planar.JPGSac for from stock subassembly shoulder extend all.JPG
PeterKozub
Figured it out planar roads need a lane "width" parameter
Note not all Stock subassemblys support a "Lane" ie have one,
for planar to work you have to have subassembly with a lane width
so C3D can use the "lanewidth" for planar roads.
So if building a planar road look to a
SAC built see Subassembly.PKS_Right_Side_Rail_Complete
Note not all Stock subassembly support a "Lane" or have one
So in SAC make a Parameter with Width much like
Subassembly.LaneSuperelevationAOR
which makes a nice planar road.
So in SAC make a Parameter with Width much like stock
which makes a nice planar road because it has a lane "width"
Please review updated 2017 C3D Dwg note low rail position at 99.00 FG top rail
Pete
Note low rail is good at elev 99_0.JPGRequire lane in SAC and Yes Potential pivot.JPG
Are you using 2018? If so, forget about superelevation and use offset alignments and dynamic offset profiles.  Much simpler to control
see my AU class Dynamic Offset Profile,  not railways but you’ll get the idea
PeterKozub
Hi
Thanks for the lead
I will give it a watch
using 2017 right now
could install 2018
and give it a shot at the railway   superelevated sidewalk
Regards
Pete
