Civil 3D Forum
subassembly
10 REPLIES 10
Message 1 of 11
shashimanandhar1417
785 Views, 10 Replies
subassembly
I have to model a corridor along a flood defence system. I have a situation where I have to create subassembly so that I can drag the bottom points along the surface to points defined as shown on attached image clip. The bottom points location varies section to section. Any idea how do I create subassembly which would create corridor according to my requirements.
10 REPLIES 10
Message 2 of 11
in reply to: shashimanandhar1417
First at all, Hi men,
Then could you please give us more details?
Do you have a polylign as a target or you are looking for a surface as a target?
Message 3 of 11
shashimanandhar1417
Haykel,
The attached image is just a sketch. Actually I have Surface as a target. Thanks for your response.
Tags (2)
Message 4 of 11
How are your bottom points defined in Civil3D?
Do you have two polylines along your axis?
Message 5 of 11
shashimanandhar1417
Haykel,
Thanks for response. I can join the bottom points where the corridor meets the surface and make 3d Polylines. The point is can I create a subassembly which will allow to stretch the end of the inclined lines ("daylight") to meet the assigned points section by section basis.
Message 6 of 11
Are you saying that the daylight point will vary from section to section?  That sounds like the job for a target alignment.  Create an alignment that has a PI at the daylight location at each section.  Then have your corridor target that alignment.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 7 of 11
Doni,
Thanks for your response. You might be right. But I have not yet tested your option. Further to clarify my situation I have attached a file where sections are superimposed at same datum. I think this sketch will tell you clearly what need to be done. Would the concept of creating target alignment solve this problem.
Message 8 of 11
With regards to my previous post. Just to note that attached was just an example sections. I have got the sections at 200m intervals for 30.2 km.
Message 9 of 11
If I understand you correctly your slope at different chainage varies and daylight points in plan are fixed. Then I think you just need an offset target for your daylight link.
Message 10 of 11
Dexterel
in reply to: Yonas89
To understand better:
You have 3 surfaces and an left and right offset target (alignment or polyline)
Every 200m you need to target a different surface (by rotation)?
So on station 190 you target first surface and on station 201 you target the next surface?
Message 11 of 11
Doni49,
Thanks for your suggestion. Just today I got opportunity to get back to this problem and I did as you suggested and it worked. I used daylight from "LinkOffsetOnSurface" and targeted that link to the Alignments that I assigned for the Left and Right constrains. Yonaa89 is also right. Thanks to both of you and all participants.
Rail Community
