Subassembly Composer: Testing NESTED IF () AND () expression for variable code to shapecode ouput
tom_cools63N7X
tom_cools63N7X
Hello Everybody,
I want also make a .pkt file/subassembly based on decisions.
To be more detailed, i want to put a code in the shape witch is based on different factors that will be determined in Civil3d by inputparameters. So one combination off that factors needs to give one unique code.
But the use of the "IF" and "AND" in de expression editor doesnt work in my pkt file...anyone knows why this is giving an error? The error message says (translated from dutch) "Cannot derive a general type because multiple types are possible"
I attached the pkt file also
Many tnx already if you are watching this and would give a solution for this problem!!
Grtz Tom Cools
ecfernandez
Hi @tom_cools63N7X, the error is there because you are placing zeros "0" at the end. That makes the program identify many different variable types possible. You defined your variable as "string," so if you wanted to keep your "0," you should use Ctype to change the number to string.
I removed the zeros and then your condition worked. Take a look
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
tom_cools63N7X
Wow tnx @ecfernandez for the VERY fast respons and giving me the good solution!! Grtz 🙂
ecfernandez
Hi @tom_cools63N7X, I am happy to help. Best regards 😀
Camilo Fernández
LinkedIn
