SSM Publish Using Page Setup Overrides File Size
draper.brandon
draper.brandon
I have created a dwt for the purpose of using it for using SSM "Publish Using Page Setup Override".  When selecting multiple sheets and using the pdf page setup I created to publish those sheets, the file size is significantly larger than if I did the same process except one sheet at a time and then just combined all the sheets into one.  So, everything is the exact same process except one is selecting all the sheets and publishing them compared to one at a time.  Why would the file size be larger when publishing multiple sheets? Any thoughts or help would be appreciated.
MSchille-1994
Where is this "Publish Using Page Setup Override" option?
Attitude, not Aptitude, Determines Altitude
draper.brandon
