Message 1 of 1
Subassembly Composer Points on arc and change arc angle
Hello everyone.
I would like to do something similar to a polar array in a vertical plane but using SAC. The thing is easy: Define parameter for the angle, then three points to define the arc, and you can divide the arc using aux lines with from the center. But i would like to do a loop controlled for a parameter to define how many times the arc is divided and get the points on the arc automatically. Thank you in advance. Cheers Pedro
