Slope Pattern
Slope Pattern
aghavamzadeh
Slope Pattern
aghavamzadeh
I try to use the function of Slope Pattern.
I pick three feature lines as shown in the pic.
The problem is that the part on the left is shown as "Fill" with two different slope pattern.
Is there a way to get it as one slope pattern?
Please see the pic.
Jeew-m
Here you should split the slope patterns into two regions.
On the fill section, define the slope pattern from ETW or edge of the road (What ever you use) to the Daylight fill.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Beka_Tchigladze
@aghavamzadeh
as I see from the screen shots it works as it must be, where you have fill it shows fill pattern and where you have cut it shows cut patterns, in case you need fill you have to modify profile. also you can change slope pattern style to show fill as green pattern and cut as red pattern to analyze visually better.
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
aghavamzadeh
I have got a software called "CADTools"...it works very well!
Beka_Tchigladze
But it is not a professional and proper way to work with corridor and it is not dynamic also.
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
