I am having an issue when using loop geometry for benching. I get geometry right and the surface is created properly, but I want to add a specific code to the end of the loop. When I add the loop, however, the code changes and I am uncertain how the loop is choosing the code to replace the ones set on the link.
This is the bench without the loop:
And this is the bench when I add the loop:
Point P19 simply shows a different code for no apparent reason and I have no idea what logic it uses to pick one from my other codes. Does anybody know why and/or how it can be fixed?
Solved by KMercier_C3D. Go to Solution.
Not sure why it doesn't behave to begin with but a workaround... After L24 add another point/link with deltax=0 and deltay=0 with no point codes on that point. Add that no length link to your loop geometry. The loop geometry will ignore the point code associated with the last link (now the zero length no point code link) and use your P19 point code since that is no longer the last link.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
The new point with no code still shows the "ghost code" in SAC, but your workaround did work. Thank you!
