Subassembly Composer - Logic of Multiple Shapes
Hi
              I have a pkt file which has the same material in different locations.Somehow i can not give the same shape NUMBER for the same shapes but i need one volume calculation for all these same shapes in the cross-sections volume tables.
              Is it just enough to name the same shape CODES for all these shapes and  does SAC consider all these shapes as one material in the cross sections and volume reports?
Thank you
KMercier_C3D
You can not duplicate a number. Using the same code will tell Civil 3D to treat the all the same, just like for a road that you have a shape of Pave1 on the left and a shape of Pave1 on the right, it will add them together.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
