Subassembly composer - curb ramp without profile
I just made curb with ramp on the driveway without making profile for curb.
In subassembly composer I set decision if pink line (picture1) is offset < or > and I have sth like that (pic3).
But of course my corridor is incomplite (pic2) so I have question is it problem for future ?
I will have gaps in earthworks or something? Cause surface look ok and for contour line plan is ok.
Is it any chance to make ramp of curb without profile ?
112233
tcorey
You definitely need a profile of the corridor baseline, but you can accomplish the curb with your assembly/subassemblies.
You say the Corridor is incomplete. Add a Point Code to the outside points of the driveway. Make sure it matches the Point Code assigned to the outside points of your curbed sections. That should fill the gaps.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
CivilFlow
Check out these methods (one C3D and one via Subassembly Composer).
Part 1
Part 2
Part 3
To answer your question, your corridor surface looks to have interpolated reasonably between assembly insertions in the driveway area, so a simple earthwork volume will not be impacted.  However, if you wanted to quantify corridor shape materials (like Curb concrete, etc), the way you have it would cause quantity takeoff to show the gaps.
I hope this helps
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
