Was wondering if anyone has come across this where within a corridor a subassembly is being placed along the alignment? In the attached image its running in the northwest direction.
Can you post your drawing?
That's what subassemblies do they follow alignments and profiles
Joe Bouza
It looks like a targeting issue from the SW-NE alignment assemblies extending along, and slightly divergent from, the NW-SE alignment. Does that SW-NE region have any targets that maybe making a loop? And as Tim suggested, can you post the drawing?
How did you drive this from the question or the picture?
Holy Cow! Its like looking for Waldo. I stared at that image for quite some time before seeing the pavement section extending up the side street.
Joe Bouza
I have a cul-de-sac at the end of the street and when I remove the baseline for the CDS its looks fine but when I add the CDS back it shows the subassembly running along the alignment again. So definitely something with the targeting.
I just had this happen. It comes from running the assembly around the edge of pavement of the cul de sac and targeting the alignment and profile of the center of the cul de sac. When it gets to a 180 of the alignment targeted is gets screwed up. Not sure how to fix it.
I have seen this too. I found it to be when the main road base line does not go to the center of the bulb
Joe Bouza
