Sub Assembly Shape Code issue
james_fisher1
james_fisher1
My theory is that the issue is with the shape codes, I want the surfaces to connect only to those surfaces at the same level. dwg attached.
It won't let me attach the pkt file, so shoot a message if you want to see additional details from it...
nkiakas
Hi @james_fisher1
Attach the pkt file by renaming it to zip file.
Also please give little more information from what do you want to do
Thank you
james_fisher1
Thanks, pkt now attached. I'm just trying to fix the corner between the two step levels. The vertices seem to connect randomly and I can't seem to make sense of why
