- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created a subassembly using SAC 2018 that is not working correctly on the left side. There are two instances of "Slope to Surface" in the routine. The first one works on both the right and left side correctly and has a default slope of -1.5:1. The second one isn't working properly on the left side. It calls for a 0.00% slope to the existing ground but in Civil 3D it draws the point and link on the right side. In fact, the link is drawn at the correct distance to the surface just in the opposite direction. I greatly simplified the routine to troubleshoot this issue and have a very simple drawing to test it in. Both are attached.
