STRUCTURE DEFORMS
STRUCTURE DEFORMS
atoledosoto
Advisor Advisor
STRUCTURE DEFORMS
atoledosoto
Hello:
When I'm editing a structure of a health network, once edited the profile changes shape, it does not regenerate as it should be.
as the block structure is damaged.
   How can i fix this
  Thank you for your help
Adalberto Toledo Soto
Charlie.Ogden
Could you explain what type of editing you do that causes this to occur?  Is it the shape of the structure on the profile that gets deformed?  Are you using a block ("display as block") for the structure in profile view?
If you could attach an image too, that would help!
Thanks!
Charlie Ogden, PE
Product Manager
atoledosoto
pozos.JPGHello
deforms in the profiles, and I am using the program data. I attached image.
Charlie.Ogden
Ok, that looks like an issue that was fixed with Service Pack 1.  Do you have that installed?  You can check Help > About...
the Product Version should say SP1.0 or SP2.0.
If not you can find the latest service pack here:
Civil 3D 2016 SP2
Charlie Ogden, PE
Product Manager
atoledosoto
Thank you very much for your support. Problem solved
atoledosoto
Hello
   I've also been having problems with the edition of Intersections, as I deleted one of the flush when editing the intersection. I'll try if this was resolved well. If not so, then I ask for help.
regards
Charlie.Ogden
Glad to hear that solved the structures problem.
If you do have an issue still with Intersections, be sure to put that in a new post.
Thanks!
Charlie Ogden, PE
Product Manager
