Strikethrough
Strikethrough
chriskVCSHB
Observer Observer
Strikethrough
chriskVCSHB
Observer
Observer
Does anyone know if you can add a strikethrough to every plan elevation at once? Maybe create a text style and assign it every one of them. Working on a lot asbuilt and I want to strike through all of the plan elevations at once without editing each individual MTEXT.
Chris
MMcCall402
I believe it will take a LISP to make this happen.
Lee Mac has a nice lisp that will draw a line, or multiple lines, across the text object as you select it.  Run a web search to find the site.
Another lisp option would be to use a lisp that can add a Prefix to the text.  Again, run a search, they're out there.  Exploding Mtext to Dtext and then prefixing them with %%K will put a strikethrough on them all at once.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
chriskVCSHB
Observer
Observer
Thank you!! I will give this a try!
tdrummZJCJP
does not work for smart labels for utility pipes or structures. need to strikethrough the length and slope on pipes and rim, station and inverts on structures. Anyone have this figured out ?
