Storm Sewers Version 11 - HGL Not Right
Message 1 of 27
I've noticed that the HGL isn't calculating or displaying correctly in Storm Sewers Version 11 in some instances. I've seen several examples where the HGL is sloping the opposite direction of the flow, which is not possible. Here are some examples.
Replies (26)
Message 21 of 27
I ran it with the "Check for Inlet Control" option selected and got similar (although not the same?) results as you, which seem reasonable to me. I'm satisfied with these results. Thanks for the help, Fred! I don't see any reason to not always run EMS with the settings, ran in a flash for this model.
Message 22 of 27
Well, so much for that. Now I'm getting bad results in another part of the model. See Line 21 below, EGL and HGL have negative slope....
Message 23 of 27
fcernst
Yes, too bad..It's doing the same thing in my 2020 version..
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Message 24 of 27
Thanks for checking. I think Autodesk needs to put some work into this program.
Message 25 of 27
fcernst
I submitted it as a support case, and Winston has told me he will be bringing it to their meeting this Friday. So we'll see.
They need to issue an hotfix to get people up and working again.
Fred Ernst, PE
C3D 2026
Ernst Engineering
Message 26 of 27
Josh_Civil
Community Visitor
Community Visitor
I am having the same issue: EGL rising in the downstream direction with no added energy from a pump, etc. "Correct EGL Discrepancies" is enabled. Was there a resolution to this issue?
Message 27 of 27
Josh_Civil
Community Visitor
Community Visitor
I am having a similar issue, i.e. EGL rising in downstream direction with no additional energy added. "Correct EGL Discrepancies" is enabled. Was there a resolution to this issue, or is this a bug with the software? Thank you.
