Storm and Sanitary Analysis - Time of Concentration
jeffY7U5X
jeffY7U5X
I am using the EPA SWMM Hydrology in SSA.  The reviewer has pointed out (rightly so) that the ToC does not compute. If a sub-basin is 100% pervious or impervious it is straightforward.  But anything else, it is some combination of the two.  I have not been able to find any documentation detailing how the total ToC is tallied.  I have tried combinations of add/sub, averaging, weighting...to no avail.  Any help would be greatly appreciated. Example below:
  • EPA SWMM Time of Concentration Computations Report
  • Tc = (0.94 * (L^0.6) * (n^0.6)) / ((i^0.4) * (S^0.3))
  • Where: Tc = Time of Concentration (min)
  • L = Flow Length (ft)
  • n = Manning's Roughness
  • i = Rainfall Intensity (in/hr)
  • S = Slope (ft/ft)
    • Subbasin SB_DP-1
    • Flow length (ft): 112.89
    • Pervious Manning's Roughness: 0.40000
    • Impervious Manning's Roughness: 0.01500
    • Pervious Rainfall Intensity (in/hr): 0.19167
    • Impervious Rainfall Intensity (in/hr): 0.19167
    • Slope (%): 1.00000
    • Computed TOC (minutes): 65.13
Hidden_Brain
what is your:
1. total area (ac)
2. Eq. width (ft)
3. % impervious
4. routing set to: direct to outlet, IP2perv or perv2IP?
jeffY7U5X
  1. Total Area = 0.38ac
  2. Eq. Width = 145ft
  3. % Imp = 14%
  4. Direct to Outlet
Hidden_Brain
I calculated 64.84 mins as the watershed TOC with your parameters.
Ac = 0.38 = 16553 SF
Eq. Width = 145 ft (this is the main input parameter in SWMM for TOC)
Length = 16553/145 = 114 ft (calculated)
%IP = 14
IP length = 0.14*114 = 16 ft
Perv Length = 114-16 = 98 ft
Using kinematic wave eqn:
IP
L = 16 ft
uniform rain = 0.19167 in/hr
S = 1% = 0.01 ft/ft
N = 0.015
TOC = 3 mins
PERV
L = 98 ft
S = 1% = 0.01 ft/ft
N = 0.4
TOC = 64.84 mins
Routing Option - IP direct to outlet
Watershed TOC = larger of IP and Perv = 64.84 mins
