Storm and Sanitary Analysis (SSA) Report Not Showing Pipe Input Details
wshenVAE6D
Message 1 of 1
wshenVAE6D
Hi All,
Currently using SSA 2019 ver 13.094.0
When I generate report, which includes the "Pipe Input" section, the report is blank for the pipe's:
  • Diameter
  • width
  • manning's
  • entrance loss
  • exit/bend loss
  • additional loss
  • initial flow
  • flap gate
  • barrels
However, luckily, the following inputs still show up in the report for pipe details:
  • SN
  • Element ID
  • length
  • inlet invert elevation
  • outlet invert elevation
  • total drop
  • average slope
  • pipe shape
Similarly, when I choose the "Link Summary" for the "output report" generation, the following pipe details show as blank:
  • Diameter
  • Manning's
This is a recent issue. I did not have this issue before. I can work around this issue by going into one the pipe's menu "Properties..." window, generate an excel report through the "Report" button, and copy the missing pipe detail via excel into the the "Output report".
I will try with another file/project to see if I have this issue again. Wondering if anyone experienced this before and if there's a solution to this issue?
Replies (0)
