How to rotate Tee/Bend in Pressure Pipe Network when pipe run is active in 2022?
hp_chan
Message 1 of 1
hp_chan
When the pressure pipe network without pipe run function before version 2020, enter P can rotate the compass 3D plane to create vertical tee/bend and pipe network. Now, the pipe run is automatic used in pressure pipe network. However I cannot know how to create vertical tee/bend and rotate them.
Replies (0)
