- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm still relatively new to using Storm and Sanitary Analysis and one thing I've been struggling to understand is how to properly model an outlet structure that has multiple components housed in the structure.
Now, I know in HydroCAD, you can tell the program that you have a culvert outfall from a pond but then you can also communicate to the program that this culvert is connected to a box which has an orifice opening into the box that controls the flow during smaller storms and then a grate at the top of the box which of course allows a larger flows to enter the box but regardless of whether the flow enters the box through the orifice at the bottom of the box or through the grate at the top of the box, it ultimately has to pass through the culvert before it outfalls.
I could just be completely missing something but it seems to me that there is not a good way to model the above situation using Storm and Sanitary Analysis. I don't see a way to house all compents as part of one outlet and if I create multiple outlet components, how does the program understand that these are connected in series and not each having their own separate flows from the storage node (and therefore adding them together rather than determining the limiting component depending the storm/scenario)?
Thanks in advance for your help, looking forward to your input!
