Does anyone know/ have experience with XML coding of SSA_Mapping_Definition_Civil.xml file to assign different inlet properties during import of pipe network from C3D to SSA.
I have one part (GUID = "BE7C6F86-58D4-419B-BF71-CE5261D5B768" Desc = "AeccStructRectSlabTopRectFrame_Imperial") if it's on sag I want it to come as Neenah R-3067 to SSA and if it's on grade - Neenah R_3067_L_Type_L from their default catalog. I tried following:
SyntaxEditor Code Snippet
<ClassMapping>
<MatchedPart>
<Civil3DPart GUID = "BE7C6F86-58D4-419B-BF71-CE5261D5B768" Desc = "AeccStructRectSlabTopRectFrame_Imperial" InletSag = "1" /> <!-- 2x3 Curb - On Sag -->
</MatchedPart>
SSAPart Element="Inlet">
<Inlet PartNumber = "R_3067_L_Type_L" Manufacturer = "Neenah Foundry" />
</SSAPart>
</ClassMapping>
<ClassMapping>
<MatchedPart>
<Civil3DPart GUID = "BE7C6F86-58D4-419B-BF71-CE5261D5B768" Desc = "AeccStructRectSlabTopRectFrame_Imperial" InletSag = "0" /> <!-- 2x3 Curb - On Grade -->
</MatchedPart>
<SSAPart Element="Inlet">
<Inlet PartNumber = "R-3067" Manufacturer = "Neenah Foundry" /> <!--On Grade -->
</SSAPart>
</ClassMapping>
But it doesn't work probably because parameter "InletSag" isn't defined in system. Although STM file has a record...
Any help would be greatly appreciated!
Also, if its impossible to do - is it possible to set Inlet Location Parameter in CAD to be set "on Sag" instead of "on Grade" by default?
Thank you
